Time Before: 0.00151 seconds
Time After: 0.00193 seconds
Time Before: 0.00200 seconds
Time After: 0.00249 seconds
Time Before: 0.00273 seconds
Time After: 0.00285 seconds
Time Before: 0.00380 seconds
Time After: 0.00668 seconds
Time Taken: 0.00288 seconds
Time Before: 0.00290 seconds
Time After: 0.01006 seconds
Time Taken: 0.00716 seconds
Time Before: 0.01210 seconds
Time After: 0.01251 seconds
Time Before: 0.01546 seconds
Time After: 0.01664 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01132 seconds
Time After: 0.01682 seconds
Time Taken: 0.00550 seconds
Memory After: 2,261.820 KB
Time Before: 0.02338 seconds
Time After: 0.02352 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.42464 seconds
Time After: 0.42841 seconds
Time Taken: 0.00377 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.43138098716736
Time Before: 0.44321 seconds
Time After: 0.44412 seconds
Time Taken: 0.00091 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.44910 seconds
Time After: 0.45287 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789088696, location = '/forums/private.php?do=newpm&explain=1&u=128062', badlocation = 1
Time Before: 0.47660 seconds
Time After: 0.47806 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.4754650592804 seconds with 9 queries, spending 0.015127182006836 doing MySQL queries and 0.46033787727356 doing PHP things.
