Time Before: 0.00147 seconds
Time After: 0.00193 seconds
Time Before: 0.00200 seconds
Time After: 0.00256 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00285 seconds
Time After: 0.00301 seconds
Time Before: 0.00387 seconds
Time After: 0.00619 seconds
Time Taken: 0.00232 seconds
Time Before: 0.00309 seconds
Time After: 0.00993 seconds
Time Taken: 0.00684 seconds
Time Before: 0.01173 seconds
Time After: 0.01213 seconds
Time Before: 0.01493 seconds
Time After: 0.01635 seconds
Time Before: 0.01113 seconds
Time After: 0.01653 seconds
Time Taken: 0.00540 seconds
Time Before: 0.02157 seconds
Time After: 0.02176 seconds
Time Before: 0.02351 seconds
Time After: 0.02477 seconds
Time Before: 0.02906 seconds
Time After: 0.02925 seconds
Time Before: 0.03229 seconds
Time After: 0.03376 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=128083' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.04852 seconds
Time After: 0.05077 seconds
Time Taken: 0.00226 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
