Time Before: 0.03917 seconds
Time After: 0.05300 seconds
Time Taken: 0.01383 seconds
Memory Before: 532.883 KB
Memory After: 558.000 KB
Time Before: 0.05308 seconds
Time After: 0.05347 seconds
Memory Before: 557.938 KB
Memory After: 558.945 KB
Time Before: 0.05372 seconds
Time After: 0.05386 seconds
Memory Before: 559.500 KB
Memory After: 560.023 KB
Time Before: 0.05473 seconds
Time After: 0.05749 seconds
Time Taken: 0.00276 seconds
Memory Before: 562.625 KB
Memory After: 563.547 KB
Time Before: 0.05392 seconds
Time After: 0.06237 seconds
Time Taken: 0.00845 seconds
Memory Before: 559.273 KB
Memory After: 1,640.320 KB
Memory Used: 1,081.047 KB
Time Before: 0.07636 seconds
Time After: 0.07679 seconds
Memory Before: 2,135.250 KB
Memory After: 2,135.867 KB
Time Before: 0.08005 seconds
Time After: 0.08155 seconds
Time Taken: 0.00150 seconds
Memory Before: 2,147.414 KB
Memory After: 2,147.273 KB
Time Before: 0.07564 seconds
Time After: 0.08177 seconds
Time Taken: 0.00613 seconds
Memory Before: 2,127.430 KB
Memory After: 2,260.641 KB
Memory Used: 133.211 KB
Time Before: 0.13450 seconds
Time After: 0.13464 seconds
Memory Before: 2,814.180 KB
Memory After: 2,814.695 KB
Time Before: 0.16198 seconds
Time After: 0.16321 seconds
Memory Before: 2,902.500 KB
Memory After: 2,903.094 KB
End call of global.php: 0.16534900665283
Time Before: 0.17274 seconds
Time After: 0.17290 seconds
Memory Before: 3,539.297 KB
Memory After: 3,539.727 KB
Time Before: 0.17550 seconds
Time After: 0.17700 seconds
Memory Before: 3,820.828 KB
Memory After: 3,822.516 KB
SET lastactivity = 1785306114, location = '/forums/private.php?do=newpm&explain=1&u=128117'
Time Before: 0.19938 seconds
Time After: 0.19970 seconds
Memory Before: 4,299.156 KB
Memory After: 4,299.383 KB
Page generated in 0.19817209243774 seconds with 9 queries, spending 0.0085594654083252 doing MySQL queries and 0.18961262702942 doing PHP things.
