Time Before: 0.02318 seconds
Time After: 0.03078 seconds
Time Taken: 0.00760 seconds
Time Before: 0.03085 seconds
Time After: 0.03127 seconds
Time Before: 0.03154 seconds
Time After: 0.03168 seconds
Time Before: 0.03248 seconds
Time After: 0.03505 seconds
Time Taken: 0.00257 seconds
Time Before: 0.03177 seconds
Time After: 0.03919 seconds
Time Taken: 0.00742 seconds
Time Before: 0.04600 seconds
Time After: 0.04642 seconds
Time Before: 0.04899 seconds
Time After: 0.05024 seconds
Time Before: 0.04524 seconds
Time After: 0.05049 seconds
Time Taken: 0.00526 seconds
Time Before: 0.08972 seconds
Time After: 0.08988 seconds
Time Before: 0.11615 seconds
Time After: 0.11742 seconds
End call of global.php: 0.11959409713745
Time Before: 0.12835 seconds
Time After: 0.12858 seconds
Time Before: 0.13116 seconds
Time After: 0.13260 seconds
SET lastactivity = 1783414864, location = '/forums/private.php?do=newpm&explain=1&u=128197'
WHERE sessionhash = '785a5ccc852039ad054a2e3a39163c15'
Time Before: 0.15172 seconds
Time After: 0.15205 seconds
Memory Before: 4,289.063 KB
Memory After: 4,289.289 KB
Page generated in 0.15073895454407 seconds with 9 queries, spending 0.0082404613494873 doing MySQL queries and 0.14249849319458 doing PHP things.
