Time Before: 0.00485 seconds
Time After: 0.00652 seconds
Time Taken: 0.00167 seconds
Time Before: 0.00666 seconds
Time After: 0.00710 seconds
Time Before: 0.00741 seconds
Time After: 0.00754 seconds
Time Before: 0.00844 seconds
Time After: 0.01082 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00762 seconds
Time After: 0.01552 seconds
Time Taken: 0.00790 seconds
Time Before: 0.01812 seconds
Time After: 0.01863 seconds
Time Before: 0.02121 seconds
Time After: 0.02240 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01737 seconds
Time After: 0.02265 seconds
Time Taken: 0.00528 seconds
Memory After: 2,261.820 KB
Time Before: 0.03132 seconds
Time After: 0.03146 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.03571 seconds
Time After: 0.03701 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.039683103561401
Time Before: 0.04143 seconds
Time After: 0.04159 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.04509 seconds
Time After: 0.04709 seconds
Time Taken: 0.00201 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788886989, location = '/forums/private.php?do=newpm&explain=1&u=128253'
Time Before: 0.06248 seconds
Time After: 0.06292 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.061545133590698 seconds with 9 queries, spending 0.0086960792541504 doing MySQL queries and 0.052849054336548 doing PHP things.
