Time Before: 0.01102 seconds
Time After: 0.01363 seconds
Time Taken: 0.00260 seconds
Time Before: 0.01372 seconds
Time After: 0.01412 seconds
Time Before: 0.01435 seconds
Time After: 0.01446 seconds
Time Before: 0.01538 seconds
Time After: 0.01878 seconds
Time Taken: 0.00339 seconds
Time Before: 0.01452 seconds
Time After: 0.02293 seconds
Time Taken: 0.00840 seconds
Time Before: 0.02711 seconds
Time After: 0.02747 seconds
Time Before: 0.03009 seconds
Time After: 0.03130 seconds
Time Before: 0.02638 seconds
Time After: 0.03152 seconds
Time Taken: 0.00514 seconds
Time Before: 0.05271 seconds
Time After: 0.05289 seconds
Time Before: 0.06039 seconds
Time After: 0.06159 seconds
Time Before: 0.06800 seconds
Time After: 0.06818 seconds
Time Before: 0.07140 seconds
Time After: 0.07285 seconds
UPDATE session SET lastactivity = 1776647707, location = '/forums/private.php?do=newpm&explain=1&u=128270' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.09173 seconds
Time After: 0.09199 seconds
