Time Before: 0.02158 seconds
Time After: 0.03261 seconds
Time Taken: 0.01103 seconds
Time Before: 0.03269 seconds
Time After: 0.03310 seconds
Time Before: 0.03338 seconds
Time After: 0.03354 seconds
Time Before: 0.03444 seconds
Time After: 0.03784 seconds
Time Taken: 0.00340 seconds
Time Before: 0.03362 seconds
Time After: 0.04243 seconds
Time Taken: 0.00881 seconds
Time Before: 0.05462 seconds
Time After: 0.05504 seconds
Time Before: 0.05662 seconds
Time After: 0.05779 seconds
Time Taken: 0.00118 seconds
Time Before: 0.05384 seconds
Time After: 0.05796 seconds
Time Taken: 0.00412 seconds
Time Before: 0.10731 seconds
Time After: 0.10746 seconds
Time Before: 0.13288 seconds
Time After: 0.13414 seconds
End call of global.php: 0.13619899749756
Time Before: 0.14607 seconds
Time After: 0.14623 seconds
Time Before: 0.14955 seconds
Time After: 0.15121 seconds
Time Taken: 0.00165 seconds
SET lastactivity = 1776690179, location = '/forums/private.php?do=newpm&explain=1&u=128280'
Time Before: 0.17755 seconds
Time After: 0.17785 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.1764190196991 seconds with 9 queries, spending 0.009091854095459 doing MySQL queries and 0.16732716560364 doing PHP things.
