Time Before: 0.01533 seconds
Time After: 0.01929 seconds
Time Taken: 0.00396 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.01940 seconds
Time After: 0.01988 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02020 seconds
Time After: 0.02034 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02126 seconds
Time After: 0.02398 seconds
Time Taken: 0.00272 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02042 seconds
Time After: 0.02820 seconds
Time Taken: 0.00778 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03386 seconds
Time After: 0.03421 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.03690 seconds
Time After: 0.03848 seconds
Time Taken: 0.00158 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.03305 seconds
Time After: 0.03874 seconds
Time Taken: 0.00569 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.07380 seconds
Time After: 0.07413 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.19618 seconds
Time After: 0.19739 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
End call of global.php: 0.19964098930359
Time Before: 0.21672 seconds
Time After: 0.21700 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.22266 seconds
Time After: 0.22411 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=128344', badlocation = 1
WHERE sessionhash = '84a1ba763b341c65c6e779f4d27b10fd'
Time Before: 0.24882 seconds
Time After: 0.24915 seconds
Memory Before: 5,997.836 KB
Memory After: 5,998.055 KB
Page generated in 0.24738788604736 seconds with 9 queries, spending 0.0088868141174316 doing MySQL queries and 0.23850107192993 doing PHP things.
