Time Before: 0.01488 seconds
Time After: 0.02252 seconds
Time Taken: 0.00764 seconds
Time Before: 0.02263 seconds
Time After: 0.02322 seconds
Time Taken: 0.00059 seconds
Time Before: 0.02348 seconds
Time After: 0.02367 seconds
Time Before: 0.02458 seconds
Time After: 0.02689 seconds
Time Taken: 0.00231 seconds
Time Before: 0.02374 seconds
Time After: 0.03250 seconds
Time Taken: 0.00876 seconds
Time Before: 0.04121 seconds
Time After: 0.04165 seconds
Time Before: 0.04420 seconds
Time After: 0.04565 seconds
Time Before: 0.04047 seconds
Time After: 0.04588 seconds
Time Taken: 0.00541 seconds
Time Before: 0.06772 seconds
Time After: 0.06802 seconds
Time Before: 0.08888 seconds
Time After: 0.09018 seconds
Time Taken: 0.00131 seconds
Time Before: 0.10243 seconds
Time After: 0.10260 seconds
Time Before: 0.10484 seconds
Time After: 0.10629 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=128364', badlocation = 1 WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.12469 seconds
Time After: 0.12499 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
