Time Before: 0.00134 seconds
Time After: 0.00186 seconds
Time Before: 0.00193 seconds
Time After: 0.00253 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00281 seconds
Time After: 0.00292 seconds
Time Before: 0.00364 seconds
Time After: 0.00613 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00297 seconds
Time After: 0.00951 seconds
Time Taken: 0.00655 seconds
Time Before: 0.01149 seconds
Time After: 0.01172 seconds
Time Before: 0.01314 seconds
Time After: 0.01433 seconds
Time Before: 0.01096 seconds
Time After: 0.01450 seconds
Time Taken: 0.00355 seconds
Time Before: 0.01957 seconds
Time After: 0.01980 seconds
Time Before: 0.02173 seconds
Time After: 0.02299 seconds
End call of global.php: 0.024600028991699
Time Before: 0.02588 seconds
Time After: 0.02611 seconds
Time Before: 0.02824 seconds
Time After: 0.02972 seconds
SET lastactivity = 1784906689, location = '/forums/private.php?do=newpm&explain=1&u=128383', badlocation = 1
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04199 seconds
Time After: 0.04233 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.041089057922363 seconds with 9 queries, spending 0.0081691741943359 doing MySQL queries and 0.032919883728027 doing PHP things.
