Time Before: 0.01697 seconds
Time After: 0.02052 seconds
Time Taken: 0.00355 seconds
Time Before: 0.02062 seconds
Time After: 0.02102 seconds
Time Before: 0.02125 seconds
Time After: 0.02139 seconds
Time Before: 0.02231 seconds
Time After: 0.02473 seconds
Time Taken: 0.00242 seconds
Time Before: 0.02145 seconds
Time After: 0.02885 seconds
Time Taken: 0.00740 seconds
Time Before: 0.03629 seconds
Time After: 0.03669 seconds
Time Before: 0.03974 seconds
Time After: 0.04093 seconds
Time Before: 0.03563 seconds
Time After: 0.04116 seconds
Time Taken: 0.00553 seconds
Time Before: 0.06896 seconds
Time After: 0.06910 seconds
Time Before: 0.08340 seconds
Time After: 0.08460 seconds
Time Before: 0.09328 seconds
Time After: 0.09344 seconds
Time Before: 0.09696 seconds
Time After: 0.09841 seconds
UPDATE session SET lastactivity = 1776729844, location = '/forums/private.php?do=newpm&explain=1&u=128442' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.11452 seconds
Time After: 0.11480 seconds
