Time Before: 0.00185 seconds
Time After: 0.00243 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00253 seconds
Time After: 0.00299 seconds
Time Before: 0.00328 seconds
Time After: 0.00348 seconds
Time Before: 0.00437 seconds
Time After: 0.00660 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00356 seconds
Time After: 0.01041 seconds
Time Taken: 0.00686 seconds
Time Before: 0.01313 seconds
Time After: 0.01359 seconds
Time Before: 0.01647 seconds
Time After: 0.01767 seconds
Time Before: 0.01235 seconds
Time After: 0.01793 seconds
Time Taken: 0.00557 seconds
Time Before: 0.02378 seconds
Time After: 0.02394 seconds
Time Before: 0.02600 seconds
Time After: 0.02720 seconds
End call of global.php: 0.028947114944458
Time Before: 0.03008 seconds
Time After: 0.03022 seconds
Time Before: 0.03241 seconds
Time After: 0.03390 seconds
SET lastactivity = 1788961275, location = '/forums/private.php?do=newpm&explain=1&u=128509'
Time Before: 0.04919 seconds
Time After: 0.04948 seconds
Page generated in 0.048290967941284 seconds with 9 queries, spending 0.0078175067901611 doing MySQL queries and 0.040473461151123 doing PHP things.
