Time Before: 0.00178 seconds
Time After: 0.00230 seconds
Time Before: 0.00237 seconds
Time After: 0.00279 seconds
Time Before: 0.00301 seconds
Time After: 0.00315 seconds
Time Before: 0.00391 seconds
Time After: 0.00653 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00320 seconds
Time After: 0.00990 seconds
Time Taken: 0.00670 seconds
Time Before: 0.01208 seconds
Time After: 0.01251 seconds
Time Before: 0.01561 seconds
Time After: 0.01704 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01144 seconds
Time After: 0.01723 seconds
Time Taken: 0.00578 seconds
Memory After: 2,261.820 KB
Time Before: 0.02271 seconds
Time After: 0.02321 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02609 seconds
Time After: 0.02738 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.03077 seconds
Time After: 0.03093 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03304 seconds
Time After: 0.03447 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788985294, location = '/forums/private.php?do=newpm&explain=1&u=128528', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04723 seconds
Time After: 0.04766 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
