Time Before: 0.00349 seconds
Time After: 0.00436 seconds
Time Taken: 0.00087 seconds
Time Before: 0.00451 seconds
Time After: 0.00557 seconds
Time Taken: 0.00106 seconds
Time Before: 0.00600 seconds
Time After: 0.00627 seconds
Time Before: 0.00719 seconds
Time After: 0.01102 seconds
Time Taken: 0.00382 seconds
Time Before: 0.00638 seconds
Time After: 0.01513 seconds
Time Taken: 0.00875 seconds
Time Before: 0.01710 seconds
Time After: 0.01759 seconds
Time Before: 0.02013 seconds
Time After: 0.02132 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01650 seconds
Time After: 0.02161 seconds
Time Taken: 0.00511 seconds
Time Before: 0.02738 seconds
Time After: 0.02754 seconds
Time Before: 0.02962 seconds
Time After: 0.03092 seconds
End call of global.php: 0.033504962921143
Time Before: 0.03488 seconds
Time After: 0.03504 seconds
Time Before: 0.03786 seconds
Time After: 0.04015 seconds
Time Taken: 0.00229 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=128639', badlocation = 1
Time Before: 0.05944 seconds
Time After: 0.05980 seconds
Page generated in 0.058110952377319 seconds with 9 queries, spending 0.011088848114014 doing MySQL queries and 0.047022104263306 doing PHP things.
