Time Before: 0.02864 seconds
Time After: 0.03773 seconds
Time Taken: 0.00909 seconds
Time Before: 0.03781 seconds
Time After: 0.03821 seconds
Time Before: 0.03845 seconds
Time After: 0.03863 seconds
Time Before: 0.03935 seconds
Time After: 0.04184 seconds
Time Taken: 0.00249 seconds
Time Before: 0.03868 seconds
Time After: 0.04593 seconds
Time Taken: 0.00724 seconds
Time Before: 0.05503 seconds
Time After: 0.05542 seconds
Time Before: 0.05789 seconds
Time After: 0.06036 seconds
Time Taken: 0.00247 seconds
Time Before: 0.05428 seconds
Time After: 0.06063 seconds
Time Taken: 0.00635 seconds
Time Before: 0.10833 seconds
Time After: 0.10851 seconds
Time Before: 0.13059 seconds
Time After: 0.13187 seconds
End call of global.php: 0.13411688804626
Time Before: 0.14309 seconds
Time After: 0.14333 seconds
Time Before: 0.14592 seconds
Time After: 0.14748 seconds
Time Taken: 0.00156 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=12864'
Time Before: 0.16901 seconds
Time After: 0.16931 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.16785383224487 seconds with 9 queries, spending 0.0094747543334961 doing MySQL queries and 0.15837907791138 doing PHP things.
