Time Before: 0.00381 seconds
Time After: 0.00487 seconds
Time Taken: 0.00106 seconds
Memory Before: 532.289 KB
Memory After: 557.406 KB
Time Before: 0.00497 seconds
Time After: 0.00537 seconds
Memory Before: 557.344 KB
Memory After: 558.352 KB
Time Before: 0.00557 seconds
Time After: 0.00583 seconds
Memory Before: 558.906 KB
Memory After: 559.430 KB
Time Before: 0.00692 seconds
Time After: 0.00936 seconds
Time Taken: 0.00243 seconds
Memory Before: 562.031 KB
Memory After: 562.953 KB
Time Before: 0.00591 seconds
Time After: 0.01509 seconds
Time Taken: 0.00918 seconds
Memory Before: 558.680 KB
Memory After: 1,639.734 KB
Memory Used: 1,081.055 KB
Time Before: 0.01753 seconds
Time After: 0.01801 seconds
Memory Before: 2,134.656 KB
Memory After: 2,135.273 KB
Time Before: 0.02083 seconds
Time After: 0.02202 seconds
Memory Before: 2,146.719 KB
Memory After: 2,146.578 KB
Time Before: 0.01675 seconds
Time After: 0.02235 seconds
Time Taken: 0.00560 seconds
Memory Before: 2,126.836 KB
Memory After: 2,259.930 KB
Memory Used: 133.094 KB
Time Before: 0.02851 seconds
Time After: 0.02870 seconds
Memory Before: 2,813.469 KB
Memory After: 2,813.984 KB
Time Before: 0.03076 seconds
Time After: 0.03200 seconds
Memory Before: 2,901.766 KB
Memory After: 2,902.359 KB
End call of global.php: 0.033865928649902
Time Before: 0.03499 seconds
Time After: 0.03510 seconds
Memory Before: 3,538.555 KB
Memory After: 3,538.984 KB
Time Before: 0.03726 seconds
Time After: 0.03877 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,820.086 KB
Memory After: 3,821.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=128740', badlocation = 1
Time Before: 0.05337 seconds
Time After: 0.05355 seconds
Memory Before: 4,298.469 KB
Memory After: 4,298.695 KB
Page generated in 0.052414894104004 seconds with 9 queries, spending 0.0079977512359619 doing MySQL queries and 0.044417142868042 doing PHP things.
