Time Before: 0.02653 seconds
Time After: 0.03624 seconds
Time Taken: 0.00970 seconds
Memory Before: 532.883 KB
Memory After: 558.000 KB
Time Before: 0.03634 seconds
Time After: 0.03682 seconds
Memory Before: 557.938 KB
Memory After: 558.945 KB
Time Before: 0.03710 seconds
Time After: 0.03730 seconds
Memory Before: 559.500 KB
Memory After: 560.023 KB
Time Before: 0.03814 seconds
Time After: 0.04050 seconds
Time Taken: 0.00236 seconds
Memory Before: 562.625 KB
Memory After: 563.547 KB
Time Before: 0.03736 seconds
Time After: 0.04483 seconds
Time Taken: 0.00747 seconds
Memory Before: 559.273 KB
Memory After: 1,640.320 KB
Memory Used: 1,081.047 KB
Time Before: 0.05095 seconds
Time After: 0.05117 seconds
Memory Before: 2,135.250 KB
Memory After: 2,135.867 KB
Time Before: 0.05402 seconds
Time After: 0.05519 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,147.313 KB
Memory After: 2,147.172 KB
Time Before: 0.05017 seconds
Time After: 0.05542 seconds
Time Taken: 0.00525 seconds
Memory Before: 2,127.430 KB
Memory After: 2,260.523 KB
Memory Used: 133.094 KB
Time Before: 0.09606 seconds
Time After: 0.09621 seconds
Memory Before: 2,814.047 KB
Memory After: 2,814.563 KB
Time Before: 0.12150 seconds
Time After: 0.12282 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,902.336 KB
Memory After: 2,902.930 KB
End call of global.php: 0.12494611740112
Time Before: 0.13484 seconds
Time After: 0.13499 seconds
Memory Before: 3,539.156 KB
Memory After: 3,539.586 KB
Time Before: 0.13739 seconds
Time After: 0.13887 seconds
Memory Before: 3,820.688 KB
Memory After: 3,822.375 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=128895', badlocation = 1
Time Before: 0.15738 seconds
Time After: 0.15771 seconds
Memory Before: 4,299.023 KB
Memory After: 4,299.250 KB
Page generated in 0.15637612342834 seconds with 9 queries, spending 0.007871150970459 doing MySQL queries and 0.14850497245789 doing PHP things.
