Time Before: 0.00134 seconds
Time After: 0.00183 seconds
Time Before: 0.00190 seconds
Time After: 0.00239 seconds
Time Before: 0.00265 seconds
Time After: 0.00282 seconds
Time Before: 0.00347 seconds
Time After: 0.00629 seconds
Time Taken: 0.00281 seconds
Time Before: 0.00287 seconds
Time After: 0.00968 seconds
Time Taken: 0.00681 seconds
Time Before: 0.01140 seconds
Time After: 0.01193 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01436 seconds
Time After: 0.01574 seconds
Time Taken: 0.00138 seconds
Time Before: 0.01084 seconds
Time After: 0.01591 seconds
Time Taken: 0.00508 seconds
Time Before: 0.02101 seconds
Time After: 0.02128 seconds
Time Before: 0.02369 seconds
Time After: 0.02506 seconds
Time Taken: 0.00137 seconds
Time Before: 0.02803 seconds
Time After: 0.02830 seconds
Time Before: 0.03025 seconds
Time After: 0.03173 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=12891' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04439 seconds
Time After: 0.04463 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
