Time Before: 0.00142 seconds
Time After: 0.00191 seconds
Time Before: 0.00198 seconds
Time After: 0.00271 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00307 seconds
Time After: 0.00325 seconds
Time Before: 0.00408 seconds
Time After: 0.00759 seconds
Time Taken: 0.00351 seconds
Time Before: 0.00332 seconds
Time After: 0.01101 seconds
Time Taken: 0.00770 seconds
Time Before: 0.01332 seconds
Time After: 0.01367 seconds
Time Before: 0.01643 seconds
Time After: 0.01763 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01279 seconds
Time After: 0.01780 seconds
Time Taken: 0.00501 seconds
Memory After: 2,261.703 KB
Time Before: 0.02316 seconds
Time After: 0.02330 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02572 seconds
Time After: 0.02692 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.028524875640869
Time Before: 0.02982 seconds
Time After: 0.02994 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03187 seconds
Time After: 0.03327 seconds
Time Taken: 0.00140 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=128913', badlocation = 1
Time Before: 0.04540 seconds
Time After: 0.04564 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.044514894485474 seconds with 9 queries, spending 0.0090725421905518 doing MySQL queries and 0.035442352294922 doing PHP things.
