Time Before: 0.01440 seconds
Time After: 0.02028 seconds
Time Taken: 0.00588 seconds
Time Before: 0.02037 seconds
Time After: 0.02082 seconds
Time Before: 0.02105 seconds
Time After: 0.02121 seconds
Time Before: 0.02196 seconds
Time After: 0.02406 seconds
Time Taken: 0.00210 seconds
Time Before: 0.02126 seconds
Time After: 0.02789 seconds
Time Taken: 0.00662 seconds
Time Before: 0.03372 seconds
Time After: 0.03409 seconds
Time Before: 0.03671 seconds
Time After: 0.03791 seconds
Time Before: 0.03299 seconds
Time After: 0.03817 seconds
Time Taken: 0.00518 seconds
Time Before: 0.06572 seconds
Time After: 0.06585 seconds
Time Before: 0.08134 seconds
Time After: 0.08256 seconds
End call of global.php: 0.084549903869629
Time Before: 0.08921 seconds
Time After: 0.08936 seconds
Time Before: 0.09186 seconds
Time After: 0.09331 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=128920'
Time Before: 0.11156 seconds
Time After: 0.11195 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.11053800582886 seconds with 9 queries, spending 0.0076477527618408 doing MySQL queries and 0.10289025306702 doing PHP things.
