Time Before: 0.02577 seconds
Time After: 0.03149 seconds
Time Taken: 0.00572 seconds
Time Before: 0.03157 seconds
Time After: 0.03198 seconds
Time Before: 0.03228 seconds
Time After: 0.03241 seconds
Time Before: 0.03325 seconds
Time After: 0.03542 seconds
Time Taken: 0.00217 seconds
Time Before: 0.03249 seconds
Time After: 0.03953 seconds
Time Taken: 0.00704 seconds
Time Before: 0.04655 seconds
Time After: 0.04696 seconds
Time Before: 0.04847 seconds
Time After: 0.04969 seconds
Time Before: 0.04590 seconds
Time After: 0.04990 seconds
Time Taken: 0.00400 seconds
Time Before: 0.08908 seconds
Time After: 0.08920 seconds
Time Before: 0.10987 seconds
Time After: 0.11110 seconds
Time Before: 0.12040 seconds
Time After: 0.12055 seconds
Time Before: 0.12289 seconds
Time After: 0.12435 seconds
UPDATE session SET lastactivity = 1776522520, location = '/forums/private.php?do=newpm&explain=1&u=128925' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.14213 seconds
Time After: 0.14242 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
