Time Before: 0.01043 seconds
Time After: 0.01409 seconds
Time Taken: 0.00366 seconds
Time Before: 0.01419 seconds
Time After: 0.01462 seconds
Time Before: 0.01484 seconds
Time After: 0.01497 seconds
Time Before: 0.01571 seconds
Time After: 0.01812 seconds
Time Taken: 0.00242 seconds
Time Before: 0.01504 seconds
Time After: 0.02293 seconds
Time Taken: 0.00789 seconds
Time Before: 0.02677 seconds
Time After: 0.02725 seconds
Time Before: 0.02870 seconds
Time After: 0.02985 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02604 seconds
Time After: 0.03008 seconds
Time Taken: 0.00403 seconds
Memory After: 2,261.703 KB
Time Before: 0.05110 seconds
Time After: 0.05125 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.05864 seconds
Time After: 0.05988 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.06587 seconds
Time After: 0.06603 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.06856 seconds
Time After: 0.07006 seconds
Time Taken: 0.00150 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=128933' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.08591 seconds
Time After: 0.08639 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
