Time Before: 0.00154 seconds
Time After: 0.00205 seconds
Time Before: 0.00212 seconds
Time After: 0.00251 seconds
Time Before: 0.00273 seconds
Time After: 0.00283 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00364 seconds
Time After: 0.00640 seconds
Time Taken: 0.00276 seconds
Time Before: 0.00288 seconds
Time After: 0.01211 seconds
Time Taken: 0.00923 seconds
Time Before: 0.01416 seconds
Time After: 0.01476 seconds
Time Taken: 0.00060 seconds
Time Before: 0.01745 seconds
Time After: 0.01897 seconds
Time Taken: 0.00152 seconds
Time Before: 0.01352 seconds
Time After: 0.01922 seconds
Time Taken: 0.00570 seconds
Time Before: 0.02541 seconds
Time After: 0.02555 seconds
Time Before: 0.02785 seconds
Time After: 0.02914 seconds
Time Before: 0.03220 seconds
Time After: 0.03234 seconds
Time Before: 0.03479 seconds
Time After: 0.03627 seconds
UPDATE session SET lastactivity = 1782996354, location = '/forums/private.php?do=newpm&explain=1&u=129101', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.04964 seconds
Time After: 0.04993 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
