Time Before: 0.00327 seconds
Time After: 0.00390 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00397 seconds
Time After: 0.00442 seconds
Time Before: 0.00462 seconds
Time After: 0.00474 seconds
Time Before: 0.00549 seconds
Time After: 0.00777 seconds
Time Taken: 0.00228 seconds
Time Before: 0.00478 seconds
Time After: 0.01122 seconds
Time Taken: 0.00643 seconds
Time Before: 0.01397 seconds
Time After: 0.01441 seconds
Time Before: 0.01726 seconds
Time After: 0.01856 seconds
Time Before: 0.01262 seconds
Time After: 0.01886 seconds
Time Taken: 0.00623 seconds
Time Before: 0.02822 seconds
Time After: 0.02834 seconds
Time Before: 0.03150 seconds
Time After: 0.03282 seconds
Time Taken: 0.00132 seconds
Time Before: 0.03705 seconds
Time After: 0.03722 seconds
Time Before: 0.04064 seconds
Time After: 0.04216 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1784773418, location = '/forums/private.php?do=newpm&explain=1&u=129121' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.06221 seconds
Time After: 0.06247 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
