Time Before: 0.00161 seconds
Time After: 0.00207 seconds
Time Before: 0.00214 seconds
Time After: 0.00261 seconds
Time Before: 0.00285 seconds
Time After: 0.00303 seconds
Time Before: 0.00382 seconds
Time After: 0.00654 seconds
Time Taken: 0.00272 seconds
Time Before: 0.00309 seconds
Time After: 0.01226 seconds
Time Taken: 0.00917 seconds
Time Before: 0.01443 seconds
Time After: 0.01478 seconds
Time Before: 0.01779 seconds
Time After: 0.01902 seconds
Time Before: 0.01370 seconds
Time After: 0.01927 seconds
Time Taken: 0.00558 seconds
Time Before: 0.02593 seconds
Time After: 0.02605 seconds
Time Before: 0.02779 seconds
Time After: 0.02915 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.031836986541748
Time Before: 0.03324 seconds
Time After: 0.03342 seconds
Time Before: 0.03622 seconds
Time After: 0.03770 seconds
SET lastactivity = 1789078840, location = '/forums/private.php?do=newpm&explain=1&u=129189'
Time Before: 0.05181 seconds
Time After: 0.05216 seconds
Page generated in 0.050875902175903 seconds with 9 queries, spending 0.0084412097930908 doing MySQL queries and 0.042434692382812 doing PHP things.
