Time Before: 0.00232 seconds
Time After: 0.00279 seconds
Time Before: 0.00286 seconds
Time After: 0.00322 seconds
Time Before: 0.00341 seconds
Time After: 0.00362 seconds
Time Before: 0.00424 seconds
Time After: 0.00673 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00367 seconds
Time After: 0.01006 seconds
Time Taken: 0.00639 seconds
Time Before: 0.01177 seconds
Time After: 0.01211 seconds
Time Before: 0.01455 seconds
Time After: 0.01590 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01125 seconds
Time After: 0.01607 seconds
Time Taken: 0.00482 seconds
Time Before: 0.02087 seconds
Time After: 0.02106 seconds
Time Before: 0.02315 seconds
Time After: 0.02457 seconds
Time Before: 0.02746 seconds
Time After: 0.02764 seconds
Time Before: 0.02999 seconds
Time After: 0.03141 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=129265', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04457 seconds
Time After: 0.04496 seconds
