Time Before: 0.00144 seconds
Time After: 0.00195 seconds
Time Before: 0.00202 seconds
Time After: 0.00253 seconds
Time Before: 0.00278 seconds
Time After: 0.00293 seconds
Time Before: 0.00361 seconds
Time After: 0.00649 seconds
Time Taken: 0.00288 seconds
Time Before: 0.00298 seconds
Time After: 0.00994 seconds
Time Taken: 0.00696 seconds
Time Before: 0.01214 seconds
Time After: 0.01262 seconds
Time Before: 0.01514 seconds
Time After: 0.01645 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01135 seconds
Time After: 0.01664 seconds
Time Taken: 0.00529 seconds
Time Before: 0.02159 seconds
Time After: 0.02174 seconds
Time Before: 0.02365 seconds
Time After: 0.02488 seconds
End call of global.php: 0.02690601348877
Time Before: 0.02828 seconds
Time After: 0.02845 seconds
Time Before: 0.03080 seconds
Time After: 0.03233 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=129284', badlocation = 1
Time Before: 0.04581 seconds
Time After: 0.04615 seconds
Page generated in 0.044471025466919 seconds with 9 queries, spending 0.0087511539459229 doing MySQL queries and 0.035719871520996 doing PHP things.
