Time Before: 0.02154 seconds
Time After: 0.02602 seconds
Time Taken: 0.00448 seconds
Time Before: 0.02611 seconds
Time After: 0.02654 seconds
Time Before: 0.02681 seconds
Time After: 0.02696 seconds
Time Before: 0.02791 seconds
Time After: 0.03033 seconds
Time Taken: 0.00242 seconds
Time Before: 0.02701 seconds
Time After: 0.03429 seconds
Time Taken: 0.00728 seconds
Time Before: 0.04357 seconds
Time After: 0.04400 seconds
Time Before: 0.04724 seconds
Time After: 0.04851 seconds
Time Before: 0.04286 seconds
Time After: 0.04878 seconds
Time Taken: 0.00591 seconds
Time Before: 0.10356 seconds
Time After: 0.10376 seconds
Time Before: 0.12701 seconds
Time After: 0.12825 seconds
Time Before: 0.13798 seconds
Time After: 0.13817 seconds
Time Before: 0.14146 seconds
Time After: 0.14304 seconds
Time Taken: 0.00157 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=129287' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.16355 seconds
Time After: 0.16381 seconds
