Time Before: 0.01328 seconds
Time After: 0.01765 seconds
Time Taken: 0.00437 seconds
Time Before: 0.01773 seconds
Time After: 0.01816 seconds
Time Before: 0.01841 seconds
Time After: 0.01855 seconds
Time Before: 0.01925 seconds
Time After: 0.02164 seconds
Time Taken: 0.00239 seconds
Time Before: 0.01860 seconds
Time After: 0.02583 seconds
Time Taken: 0.00722 seconds
Time Before: 0.03232 seconds
Time After: 0.03273 seconds
Time Before: 0.03524 seconds
Time After: 0.03644 seconds
Time Before: 0.03162 seconds
Time After: 0.03663 seconds
Time Taken: 0.00501 seconds
Time Before: 0.06319 seconds
Time After: 0.06336 seconds
Time Before: 0.07528 seconds
Time After: 0.07655 seconds
End call of global.php: 0.078606843948364
Time Before: 0.08135 seconds
Time After: 0.08152 seconds
Time Before: 0.08378 seconds
Time After: 0.08529 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=129304'
Time Before: 0.10301 seconds
Time After: 0.10335 seconds
Page generated in 0.10202097892761 seconds with 9 queries, spending 0.0080416202545166 doing MySQL queries and 0.093979358673096 doing PHP things.
