Time Before: 0.01444 seconds
Time After: 0.01857 seconds
Time Taken: 0.00413 seconds
Time Before: 0.01868 seconds
Time After: 0.01918 seconds
Time Before: 0.01942 seconds
Time After: 0.01958 seconds
Time Before: 0.02036 seconds
Time After: 0.02272 seconds
Time Taken: 0.00236 seconds
Time Before: 0.01964 seconds
Time After: 0.02674 seconds
Time Taken: 0.00709 seconds
Time Before: 0.03251 seconds
Time After: 0.03299 seconds
Time Before: 0.03549 seconds
Time After: 0.03672 seconds
Time Before: 0.03173 seconds
Time After: 0.03697 seconds
Time Taken: 0.00524 seconds
Time Before: 0.06764 seconds
Time After: 0.06781 seconds
Time Before: 0.07939 seconds
Time After: 0.08066 seconds
Time Before: 0.08953 seconds
Time After: 0.08970 seconds
Time Before: 0.09240 seconds
Time After: 0.09389 seconds
UPDATE session SET lastactivity = 1780636640, location = '/forums/private.php?do=newpm&explain=1&u=129317' WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.11007 seconds
Time After: 0.11037 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
