Time Before: 0.01983 seconds
Time After: 0.02533 seconds
Time Taken: 0.00550 seconds
Time Before: 0.02541 seconds
Time After: 0.02577 seconds
Time Before: 0.02597 seconds
Time After: 0.02615 seconds
Time Before: 0.02675 seconds
Time After: 0.02868 seconds
Time Taken: 0.00193 seconds
Time Before: 0.02621 seconds
Time After: 0.03267 seconds
Time Taken: 0.00646 seconds
Time Before: 0.04157 seconds
Time After: 0.04190 seconds
Time Before: 0.04324 seconds
Time After: 0.04443 seconds
Time Before: 0.04096 seconds
Time After: 0.04468 seconds
Time Taken: 0.00372 seconds
Time Before: 0.07473 seconds
Time After: 0.07490 seconds
Time Before: 0.56073 seconds
Time After: 0.56201 seconds
Time Before: 0.57565 seconds
Time After: 0.57582 seconds
Time Before: 0.57894 seconds
Time After: 0.58040 seconds
UPDATE session SET lastactivity = 1776458504, location = '/forums/private.php?do=newpm&explain=1&u=129320' WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 0.60217 seconds
Time After: 0.60248 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
