Time Before: 0.00184 seconds
Time After: 0.00241 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00248 seconds
Time After: 0.00288 seconds
Time Before: 0.00312 seconds
Time After: 0.00330 seconds
Time Before: 0.00395 seconds
Time After: 0.00663 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00335 seconds
Time After: 0.01154 seconds
Time Taken: 0.00819 seconds
Time Before: 0.01437 seconds
Time After: 0.01473 seconds
Time Before: 0.01754 seconds
Time After: 0.01891 seconds
Time Taken: 0.00137 seconds
Time Before: 0.01370 seconds
Time After: 0.01922 seconds
Time Taken: 0.00552 seconds
Time Before: 0.02745 seconds
Time After: 0.02764 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"24.41,\";s:9:\"lastcheck\";i:1789056519;}', 1)Time Before: 0.03445 seconds
Time After: 0.03509 seconds
Time Taken: 0.00064 seconds
Memory Before: 3,439.656 KB
Memory After: 3,439.906 KB
Memory Used: 0.250 KB
Time Before: 0.03746 seconds
Time After: 0.03880 seconds
Time Taken: 0.00133 seconds
Memory Before: 3,526.469 KB
Memory After: 3,527.063 KB
Time Before: 0.04401 seconds
Time After: 0.04415 seconds
Memory Before: 4,164.406 KB
Memory After: 4,164.836 KB
Time Before: 0.04659 seconds
Time After: 0.04812 seconds
Time Taken: 0.00153 seconds
Memory Before: 4,446.055 KB
Memory After: 4,447.742 KB
UPDATE session SET lastactivity = 1789056519, location = '/forums/private.php?do=newpm&explain=1&u=129342', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.06173 seconds
Time After: 0.06203 seconds
Memory Before: 4,920.063 KB
Memory After: 4,920.273 KB
