Time Before: 0.02407 seconds
Time After: 0.02891 seconds
Time Taken: 0.00484 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02899 seconds
Time After: 0.02940 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02965 seconds
Time After: 0.02980 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03060 seconds
Time After: 0.03312 seconds
Time Taken: 0.00252 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02988 seconds
Time After: 0.03727 seconds
Time Taken: 0.00739 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04384 seconds
Time After: 0.04424 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04668 seconds
Time After: 0.04791 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.04305 seconds
Time After: 0.04815 seconds
Time Taken: 0.00510 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.08770 seconds
Time After: 0.08784 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.13842 seconds
Time After: 0.13967 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.17209 seconds
Time After: 0.17226 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.17717 seconds
Time After: 0.17879 seconds
Time Taken: 0.00162 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1773312892, location = '/forums/private.php?do=newpm&explain=1&u=129362', badlocation = 1 WHERE sessionhash = 'eaa8a3ac54cff5a66f956999e9bca4a9'
Time Before: 0.20877 seconds
Time After: 0.20905 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
