Time Before: 0.00182 seconds
Time After: 0.00240 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00247 seconds
Time After: 0.00283 seconds
Time Before: 0.00305 seconds
Time After: 0.00316 seconds
Time Before: 0.00399 seconds
Time After: 0.00648 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00322 seconds
Time After: 0.01031 seconds
Time Taken: 0.00709 seconds
Time Before: 0.01233 seconds
Time After: 0.01277 seconds
Time Before: 0.01573 seconds
Time After: 0.01692 seconds
Time Before: 0.01175 seconds
Time After: 0.01710 seconds
Time Taken: 0.00535 seconds
Time Before: 0.02324 seconds
Time After: 0.02366 seconds
Time Before: 0.02607 seconds
Time After: 0.02733 seconds
End call of global.php: 0.029788970947266
Time Before: 0.03131 seconds
Time After: 0.03144 seconds
Time Before: 0.03378 seconds
Time After: 0.03521 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=129363'
Time Before: 0.04983 seconds
Time After: 0.05018 seconds
Page generated in 0.048917055130005 seconds with 9 queries, spending 0.0081777572631836 doing MySQL queries and 0.040739297866821 doing PHP things.
