Time Before: 0.00280 seconds
Time After: 0.00355 seconds
Time Taken: 0.00075 seconds
Time Before: 0.00363 seconds
Time After: 0.00438 seconds
Time Before: 0.00461 seconds
Time After: 0.00472 seconds
Time Before: 0.00536 seconds
Time After: 0.00786 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00477 seconds
Time After: 0.01182 seconds
Time Taken: 0.00705 seconds
Time Before: 0.01531 seconds
Time After: 0.01575 seconds
Time Before: 0.01845 seconds
Time After: 0.01962 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01314 seconds
Time After: 0.01983 seconds
Time Taken: 0.00669 seconds
Memory After: 2,261.820 KB
Time Before: 0.02751 seconds
Time After: 0.02769 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.03204 seconds
Time After: 0.03332 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.036055088043213
Time Before: 0.03763 seconds
Time After: 0.03780 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.04004 seconds
Time After: 0.04151 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788954161, location = '/forums/private.php?do=newpm&explain=1&u=129367'
Time Before: 0.05490 seconds
Time After: 0.05517 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.053975105285645 seconds with 9 queries, spending 0.0083322525024414 doing MySQL queries and 0.045642852783203 doing PHP things.
