Time Before: 0.00205 seconds
Time After: 0.00260 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00268 seconds
Time After: 0.00324 seconds
Time Before: 0.00351 seconds
Time After: 0.00365 seconds
Time Before: 0.00448 seconds
Time After: 0.00842 seconds
Time Taken: 0.00394 seconds
Time Before: 0.00372 seconds
Time After: 0.01317 seconds
Time Taken: 0.00945 seconds
Time Before: 0.01568 seconds
Time After: 0.01608 seconds
Time Before: 0.01794 seconds
Time After: 0.01917 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01510 seconds
Time After: 0.01934 seconds
Time Taken: 0.00424 seconds
Memory After: 2,261.820 KB
Time Before: 0.02443 seconds
Time After: 0.02574 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02916 seconds
Time After: 0.03068 seconds
Time Taken: 0.00152 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.03337 seconds
Time After: 0.03352 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03544 seconds
Time After: 0.03692 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788886871, location = '/forums/private.php?do=newpm&explain=1&u=129406', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04948 seconds
Time After: 0.04971 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
