Time Before: 0.01304 seconds
Time After: 0.01817 seconds
Time Taken: 0.00513 seconds
Time Before: 0.01828 seconds
Time After: 0.01873 seconds
Time Before: 0.01898 seconds
Time After: 0.01914 seconds
Time Before: 0.02013 seconds
Time After: 0.02249 seconds
Time Taken: 0.00236 seconds
Time Before: 0.01923 seconds
Time After: 0.02696 seconds
Time Taken: 0.00773 seconds
Time Before: 0.03198 seconds
Time After: 0.03240 seconds
Time Before: 0.03548 seconds
Time After: 0.03672 seconds
Time Before: 0.03118 seconds
Time After: 0.03695 seconds
Time Taken: 0.00577 seconds
Time Before: 0.05817 seconds
Time After: 0.05831 seconds
Time Before: 0.06693 seconds
Time After: 0.06816 seconds
Time Before: 0.07500 seconds
Time After: 0.07515 seconds
Time Before: 0.07758 seconds
Time After: 0.07908 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=129429', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.10220 seconds
Time After: 0.10248 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
