Time Before: 0.01026 seconds
Time After: 0.01286 seconds
Time Taken: 0.00259 seconds
Time Before: 0.01296 seconds
Time After: 0.01352 seconds
Time Taken: 0.00056 seconds
Time Before: 0.01379 seconds
Time After: 0.01393 seconds
Time Before: 0.01490 seconds
Time After: 0.01732 seconds
Time Taken: 0.00242 seconds
Time Before: 0.01399 seconds
Time After: 0.02159 seconds
Time Taken: 0.00760 seconds
Time Before: 0.02634 seconds
Time After: 0.02673 seconds
Time Before: 0.02934 seconds
Time After: 0.03054 seconds
Time Before: 0.02567 seconds
Time After: 0.03073 seconds
Time Taken: 0.00506 seconds
Time Before: 0.04769 seconds
Time After: 0.04784 seconds
Time Before: 0.05626 seconds
Time After: 0.05755 seconds
End call of global.php: 0.059348106384277
Time Before: 0.06298 seconds
Time After: 0.06311 seconds
Time Before: 0.06549 seconds
Time After: 0.06700 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1789082016, location = '/forums/private.php?do=newpm&explain=1&u=129494'
Time Before: 0.08314 seconds
Time After: 0.08343 seconds
Page generated in 0.082112073898315 seconds with 9 queries, spending 0.0080771446228027 doing MySQL queries and 0.074034929275513 doing PHP things.
