Time Before: 0.02456 seconds
Time After: 0.03133 seconds
Time Taken: 0.00678 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.03145 seconds
Time After: 0.03185 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.03209 seconds
Time After: 0.03222 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.03313 seconds
Time After: 0.03570 seconds
Time Taken: 0.00257 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.03230 seconds
Time After: 0.03976 seconds
Time Taken: 0.00745 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.04970 seconds
Time After: 0.05009 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.05154 seconds
Time After: 0.05278 seconds
Memory Before: 2,771.656 KB
Memory After: 2,771.516 KB
Time Before: 0.04884 seconds
Time After: 0.05301 seconds
Time Taken: 0.00417 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.547 KB
Time Before: 0.08895 seconds
Time After: 0.08913 seconds
Memory Before: 3,437.688 KB
Memory After: 3,438.203 KB
Time Before: 0.10926 seconds
Time After: 0.11050 seconds
Memory Before: 3,525.500 KB
Memory After: 3,526.094 KB
End call of global.php: 0.11254787445068
Time Before: 0.12135 seconds
Time After: 0.12150 seconds
Memory Before: 4,163.391 KB
Memory After: 4,163.820 KB
Time Before: 0.12397 seconds
Time After: 0.12542 seconds
Memory Before: 4,444.953 KB
Memory After: 4,446.641 KB
SET lastactivity = 1776551117, location = '/forums/private.php?do=newpm&explain=1&u=129503'
Time Before: 0.14887 seconds
Time After: 0.14927 seconds
Memory Before: 4,918.805 KB
Memory After: 4,919.031 KB
Page generated in 0.14791393280029 seconds with 9 queries, spending 0.0081613063812256 doing MySQL queries and 0.13975262641907 doing PHP things.
