Time Before: 0.00438 seconds
Time After: 0.00608 seconds
Time Taken: 0.00170 seconds
Time Before: 0.00615 seconds
Time After: 0.00656 seconds
Time Before: 0.00683 seconds
Time After: 0.00697 seconds
Time Before: 0.00761 seconds
Time After: 0.01113 seconds
Time Taken: 0.00352 seconds
Time Before: 0.00702 seconds
Time After: 0.01559 seconds
Time Taken: 0.00857 seconds
Time Before: 0.01847 seconds
Time After: 0.01886 seconds
Time Before: 0.02043 seconds
Time After: 0.02175 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01776 seconds
Time After: 0.02201 seconds
Time Taken: 0.00425 seconds
Time Before: 0.03263 seconds
Time After: 0.03276 seconds
Time Before: 0.03630 seconds
Time After: 0.03759 seconds
Time Before: 0.04169 seconds
Time After: 0.04190 seconds
Time Before: 0.04440 seconds
Time After: 0.04581 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=129591', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.06466 seconds
Time After: 0.06490 seconds
