Time Before: 0.00426 seconds
Time After: 0.00573 seconds
Time Before: 0.00583 seconds
Time After: 0.00634 seconds
Time Before: 0.00669 seconds
Time After: 0.00682 seconds
Time Before: 0.00778 seconds
Time After: 0.00983 seconds
Time Taken: 0.00206 seconds
Time Before: 0.00688 seconds
Time After: 0.01458 seconds
Time Taken: 0.00770 seconds
Time Before: 0.01800 seconds
Time After: 0.01844 seconds
Time Before: 0.02169 seconds
Time After: 0.02294 seconds
Time Before: 0.01723 seconds
Time After: 0.02323 seconds
Time Taken: 0.00600 seconds
Time Before: 0.03279 seconds
Time After: 0.03294 seconds
Time Before: 0.03697 seconds
Time After: 0.03829 seconds
Time Taken: 0.00131 seconds
Time Before: 0.04273 seconds
Time After: 0.04295 seconds
Time Before: 0.04552 seconds
Time After: 0.04699 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=129595' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.06267 seconds
Time After: 0.06297 seconds
