Time Before: 0.01890 seconds
Time After: 0.02762 seconds
Time Taken: 0.00872 seconds
Time Before: 0.02777 seconds
Time After: 0.02817 seconds
Time Before: 0.02843 seconds
Time After: 0.02856 seconds
Time Before: 0.02922 seconds
Time After: 0.03112 seconds
Time Taken: 0.00190 seconds
Time Before: 0.02861 seconds
Time After: 0.03493 seconds
Time Taken: 0.00632 seconds
Time Before: 0.04384 seconds
Time After: 0.04423 seconds
Time Before: 0.04679 seconds
Time After: 0.04797 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04323 seconds
Time After: 0.04817 seconds
Time Taken: 0.00494 seconds
Memory After: 2,261.703 KB
Time Before: 0.08704 seconds
Time After: 0.08740 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.18851 seconds
Time After: 0.18973 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.19186806678772
Time Before: 0.20098 seconds
Time After: 0.20113 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.20365 seconds
Time After: 0.20518 seconds
Time Taken: 0.00154 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=129616'
Time Before: 0.22224 seconds
Time After: 0.22247 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.22114205360413 seconds with 9 queries, spending 0.0074982643127441 doing MySQL queries and 0.21364378929138 doing PHP things.
