Time Before: 0.00199 seconds
Time After: 0.00270 seconds
Time Taken: 0.00072 seconds
Time Before: 0.00277 seconds
Time After: 0.00319 seconds
Time Before: 0.00338 seconds
Time After: 0.00358 seconds
Time Before: 0.00428 seconds
Time After: 0.00627 seconds
Time Taken: 0.00200 seconds
Time Before: 0.00363 seconds
Time After: 0.00972 seconds
Time Taken: 0.00609 seconds
Time Before: 0.01175 seconds
Time After: 0.01213 seconds
Time Before: 0.01440 seconds
Time After: 0.01560 seconds
Time Before: 0.01119 seconds
Time After: 0.01577 seconds
Time Taken: 0.00458 seconds
Time Before: 0.02116 seconds
Time After: 0.02130 seconds
Time Before: 0.02311 seconds
Time After: 0.02439 seconds
End call of global.php: 0.026015043258667
Time Before: 0.02728 seconds
Time After: 0.02744 seconds
Time Before: 0.02937 seconds
Time After: 0.03082 seconds
SET lastactivity = 1776606872, location = '/forums/private.php?do=newpm&explain=1&u=129631', badlocation = 1
Time Before: 0.04326 seconds
Time After: 0.04368 seconds
Page generated in 0.042333841323853 seconds with 9 queries, spending 0.0076446533203125 doing MySQL queries and 0.03468918800354 doing PHP things.
