Time Before: 0.00286 seconds
Time After: 0.00334 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00341 seconds
Time After: 0.00390 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00413 seconds
Time After: 0.00428 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00493 seconds
Time After: 0.00725 seconds
Time Taken: 0.00231 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00433 seconds
Time After: 0.01169 seconds
Time Taken: 0.00736 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01371 seconds
Time After: 0.01415 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01573 seconds
Time After: 0.01698 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.01301 seconds
Time After: 0.01722 seconds
Time Taken: 0.00421 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.02347 seconds
Time After: 0.02363 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 1.32594 seconds
Time After: 1.32732 seconds
Time Taken: 0.00138 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 1.3301310539246
Time Before: 1.34009 seconds
Time After: 1.34021 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 1.34301 seconds
Time After: 1.34470 seconds
Time Taken: 0.00169 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1773377413, location = '/forums/private.php?do=newpm&explain=1&u=129775', badlocation = 1
WHERE sessionhash = 'e0f0ca8e3048a6e309b58c7aba652665'
Time Before: 1.36008 seconds
Time After: 1.36027 seconds
Memory Before: 5,999.000 KB
Memory After: 5,999.211 KB
Page generated in 1.3587489128113 seconds with 9 queries, spending 0.008181095123291 doing MySQL queries and 1.350567817688 doing PHP things.
