Time Before: 0.01258 seconds
Time After: 0.01698 seconds
Time Taken: 0.00440 seconds
Time Before: 0.01708 seconds
Time After: 0.01753 seconds
Time Before: 0.01783 seconds
Time After: 0.01798 seconds
Time Before: 0.01884 seconds
Time After: 0.02133 seconds
Time Taken: 0.00250 seconds
Time Before: 0.01804 seconds
Time After: 0.02602 seconds
Time Taken: 0.00798 seconds
Time Before: 0.03240 seconds
Time After: 0.03282 seconds
Time Before: 0.03534 seconds
Time After: 0.03659 seconds
Time Before: 0.03165 seconds
Time After: 0.03682 seconds
Time Taken: 0.00517 seconds
Time Before: 0.05573 seconds
Time After: 0.05587 seconds
Time Before: 0.06822 seconds
Time After: 0.06947 seconds
End call of global.php: 0.071562051773071
Time Before: 0.07649 seconds
Time After: 0.07669 seconds
Time Before: 0.07899 seconds
Time After: 0.08046 seconds
SET lastactivity = 1783233788, location = '/forums/private.php?do=newpm&explain=1&u=129799'
Time Before: 0.09571 seconds
Time After: 0.09604 seconds
Memory Before: 4,289.063 KB
Memory After: 4,289.289 KB
Page generated in 0.094678163528442 seconds with 9 queries, spending 0.0081558227539062 doing MySQL queries and 0.086522340774536 doing PHP things.
