Time Before: 0.00219 seconds
Time After: 0.00278 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00287 seconds
Time After: 0.00329 seconds
Time Before: 0.00362 seconds
Time After: 0.00379 seconds
Time Before: 0.00459 seconds
Time After: 0.00710 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00386 seconds
Time After: 0.01217 seconds
Time Taken: 0.00831 seconds
Time Before: 0.01421 seconds
Time After: 0.01463 seconds
Time Before: 0.01792 seconds
Time After: 0.01915 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01348 seconds
Time After: 0.01943 seconds
Time Taken: 0.00595 seconds
Memory After: 2,261.820 KB
Time Before: 0.02692 seconds
Time After: 0.02707 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02949 seconds
Time After: 0.03073 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.03526 seconds
Time After: 0.03542 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03865 seconds
Time After: 0.04009 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789117229, location = '/forums/private.php?do=newpm&explain=1&u=129804' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05410 seconds
Time After: 0.05452 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
