Time Before: 0.00141 seconds
Time After: 0.00197 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00204 seconds
Time After: 0.00242 seconds
Time Before: 0.00272 seconds
Time After: 0.00294 seconds
Time Before: 0.00383 seconds
Time After: 0.00675 seconds
Time Taken: 0.00292 seconds
Time Before: 0.00302 seconds
Time After: 0.01185 seconds
Time Taken: 0.00882 seconds
Time Before: 0.01452 seconds
Time After: 0.01488 seconds
Time Before: 0.01645 seconds
Time After: 0.01767 seconds
Time Before: 0.01376 seconds
Time After: 0.01792 seconds
Time Taken: 0.00416 seconds
Time Before: 0.02385 seconds
Time After: 0.02402 seconds
Time Before: 0.02645 seconds
Time After: 0.02771 seconds
Time Before: 0.03160 seconds
Time After: 0.03177 seconds
Time Before: 0.03383 seconds
Time After: 0.03545 seconds
Time Taken: 0.00162 seconds
UPDATE session SET lastactivity = 1776801114, location = '/forums/private.php?do=newpm&explain=1&u=129829' WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.04884 seconds
Time After: 0.04919 seconds
