Time Before: 0.00178 seconds
Time After: 0.00239 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00245 seconds
Time After: 0.00305 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00329 seconds
Time After: 0.00343 seconds
Time Before: 0.00410 seconds
Time After: 0.00628 seconds
Time Taken: 0.00218 seconds
Time Before: 0.00348 seconds
Time After: 0.01150 seconds
Time Taken: 0.00802 seconds
Time Before: 0.01343 seconds
Time After: 0.01384 seconds
Time Before: 0.01621 seconds
Time After: 0.01740 seconds
Time Before: 0.01279 seconds
Time After: 0.01760 seconds
Time Taken: 0.00480 seconds
Time Before: 0.02405 seconds
Time After: 0.02421 seconds
Time Before: 0.02620 seconds
Time After: 0.02743 seconds
Time Before: 0.03036 seconds
Time After: 0.03051 seconds
Time Before: 0.03268 seconds
Time After: 0.03432 seconds
Time Taken: 0.00164 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=129869' WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.04820 seconds
Time After: 0.04850 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
