Time Before: 0.02514 seconds
Time After: 0.04026 seconds
Time Taken: 0.01512 seconds
Time Before: 0.04037 seconds
Time After: 0.04078 seconds
Time Before: 0.04099 seconds
Time After: 0.04111 seconds
Time Before: 0.04187 seconds
Time After: 0.04454 seconds
Time Taken: 0.00266 seconds
Time Before: 0.04117 seconds
Time After: 0.04857 seconds
Time Taken: 0.00740 seconds
Time Before: 0.06821 seconds
Time After: 0.06867 seconds
Time Before: 0.07126 seconds
Time After: 0.07250 seconds
Time Before: 0.06731 seconds
Time After: 0.07271 seconds
Time Taken: 0.00539 seconds
Time Before: 0.10708 seconds
Time After: 0.10722 seconds
Time Before: 0.13765 seconds
Time After: 0.13888 seconds
Time Before: 0.14808 seconds
Time After: 0.14824 seconds
Time Before: 0.15052 seconds
Time After: 0.15197 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=129882', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.16985 seconds
Time After: 0.17016 seconds
