Time Before: 0.00142 seconds
Time After: 0.00195 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00202 seconds
Time After: 0.00254 seconds
Time Before: 0.00274 seconds
Time After: 0.00285 seconds
Time Before: 0.00358 seconds
Time After: 0.00658 seconds
Time Taken: 0.00300 seconds
Time Before: 0.00290 seconds
Time After: 0.01042 seconds
Time Taken: 0.00752 seconds
Time Before: 0.01213 seconds
Time After: 0.01254 seconds
Time Before: 0.01546 seconds
Time After: 0.01665 seconds
Time Before: 0.01159 seconds
Time After: 0.01683 seconds
Time Taken: 0.00524 seconds
Time Before: 0.02216 seconds
Time After: 0.02233 seconds
Time Before: 0.02479 seconds
Time After: 0.02603 seconds
Time Before: 0.03001 seconds
Time After: 0.03017 seconds
Time Before: 0.03295 seconds
Time After: 0.03507 seconds
Time Taken: 0.00212 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=129937', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04747 seconds
Time After: 0.04778 seconds
